I agree with the W/S being up an inch or so to move more air across the engine compartment. Even at speed it is apparent that the screen, moved upward a bit, makes a positive difference. At a stop, my Dyna 96CI engine puts off heat that can make breathing difficult, much worse than the C14. At speed, I still get some heat on my shins on the 14, but none on the Dyna. Both are fun rides, but very different. Ya have to ride both regularly to understand the enjoyment of both. Oh, ride the Dyna w/o a Screen, so never ride it as fast as the 14, just too much wind blast over 70 MPH.
Using a V-Stream with a laminar lip, and can still get air movement on the body, with it moved up an inch or so, and the engine heat is still lessened too. . tp
