You asked for better lighting at low cost?
I don't like the extra lights hanging on the bike but wanted more light.
Didn't want to spend the big $$..
SO,,,,
I use the NAAPA Off Road light bulb (100W80), then added a wire, switch and diode between the low and high beam wires.....
Cost about $10.00
Now, When I select Low beam, I power Low beam only....
BUT,, when I select High beam, I send electricity to both low beam and high beam ....
Lights up "Close" and "Far".......
PS: (I also have Murphs wiring Harness installed as this gives me more amps without overloading the Selector switch)..
