The C-14, aka Kawasaki Concours-14, the new one :) => The Bike - C14/GTR 1400 => Topic started by: stepink104 on September 04, 2017, 07:43:27 PM
Title: no front brakes.....need some help
Post by: stepink104 on September 04, 2017, 07:43:27 PM
guys..small mishap in garage,,,long story short bike was dropped on right side while a tire was being changed..after I got tire on I have discovered I must squeeze front brake lever several times till I have brake..2008 with abs....seen no damage to master cylinder and no leaks on floor or rims anywhere,,,i decided maybe time to change fluid...did this on bike before never had problem.
bled brakes and pump lever and have full brake,,let go of brake and several seconds later...NOTHING...any ideas...
Ken
Title: Re: no front brakes.....need some help
Post by: kzz1king on September 04, 2017, 08:22:25 PM
Did it do this after the accident BEFORE you bled the brakes?  I think you need to bleed them again.
Post by: maxtog on September 04, 2017, 08:52:03 PM
Bleed, bleed, bleed
Post by: Freddy on September 04, 2017, 09:07:02 PM
Bent disc.
Post by: VirginiaJim on September 05, 2017, 05:06:42 AM
Very possibly..
Post by: maxtog on September 05, 2017, 06:13:04 AM
Bent disc.
Yeah, that could push the pads back in.  But if the rotor were bent the brakes would pulse horribly... no mention of that.
Post by: gPink on September 05, 2017, 06:29:07 AM
pinched brake line from fall?
Post by: smokin on September 05, 2017, 09:30:49 AM
Air in system,keep bleeding.Recommend Murphs,speed bleeders.One man successful operation.
Post by: Tree on September 06, 2017, 11:53:07 AM
+1 on Speed Bleeder. I will have fresh brake fluid in the system after every tire change now because it's crazy easy to bleed.
Ken
If the brake front brake lever struck the ground it could have damaged the internal piston somehow?  Maybe?  No fluid leaking from that area?
Post by: jimmymac on September 06, 2017, 01:02:19 PM
If it only goes away when you roll it, it's the rotor. If it goes away sitting still, it's air in the system.
Post by: gPink on September 06, 2017, 02:19:41 PM
http://youtu.be/f4zyjLyBp64 (http://youtu.be/f4zyjLyBp64)
Post by: jamiemac on September 06, 2017, 08:20:34 PM
Couple of things You can do to diagnose things. First take a small piece of scrap steel, approximately the same thickness as the rotor, remove the suspected caliper and slide the scrap steel between the pads in the same spot the rotor sits. Use a zip tie or some wire to hang the caliper in a way that the hoses aren't stressed, and pump the brake until the pads clamp the steel. If the symptom is gone, then the rotor is springing the pads back into the caliper bore.
Another thing You can do requires a dial indicator. Clamp or bolt the indicator on the lower fork, and do a runout check on the rotor. Specs should be in the service manual.
This guy has a good video
https://youtu.be/2GaYqJYhCB0
Post by: Tree on September 07, 2017, 03:20:18 PM
Ken
Sooooo.  Anybody else feel like they're talking to themselves?  What's up Ken?
Post by: B.D.F. on September 07, 2017, 04:08:59 PM
Usually we see this as a user's first post, on the day the user joined the forum. But this gentleman joined in March and did not post until Sep.. ? Maybe he got his answer.
A lot more people read forums than post to them so maybe the silence is the norm. and the one post was the oddity?
Post by: jimmymac on September 07, 2017, 08:31:49 PM
Hey guys, I dropped my bike and now it's broken.  First post!
Hard to come back, no matter how bad you try to help.
Post by: jimmymac on September 09, 2017, 01:54:34 AM
Stick to your keyboard. You suck at diagnosis. Lol!
Post by: jimmymac on September 09, 2017, 01:57:12 AM
  You too.
Post by: gPink on September 09, 2017, 06:53:28 AM
freakin' harley riders....
Post by: clogan on September 10, 2017, 06:43:27 PM
If the fall caused contact to one of the rotors, it is at least possible that that rotor was damaged, or warped. As a wheel rotates, the warped rotor pushes the calipers back apart, drastically reducing, or eliminating, braking ability in that wheel.
I know this because I did the same thing myself. It was VERY surprising how easily the rotors could be damaged. I warped a rotor while breaking a bead in order to change a tire. Cost me big bucks for a new set of front rotors. I learned a very expensive lesson. Heres hoping the OP's problem can be fixed with less expense.
